I have a 76 F250 and am considering a few things I'd like opinions on. As it is, I need to replace the leaf spring bushings in the rear and am having problems finding what I'm looking for. I think I found what I need at Bronco Graveyard here: http://broncograveyard.com/bronco/i-...ngs__black.htm is this the correct part?
The other thing I've been thinking about is replacing the stock spring packs and blocks with an aftermarket spring pack that has the same lift, both to help alleviate the sag and to eliminate the lift block. Also, I'd like to replace the front spring packs that have some sag. Any suggestions?
yes those are what you are needing as for springs there is alot of places that sell springs that you are looking for just do a search or call up a offroad shop and price them they will look up what you need.
