Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
I have PMS
Old Apr 30, 2006 | 10:03 PM
Corner Gas's Avatar
Corner Gas
Smile I have PMS
I got a few mods done on the PSD yesterday, the CCV, kwik filter and the Zoodad. Everything went smoothly except for the couple of times I lost Amy. Good thing I am not getting paid to baby sit. I tried adding some pictures to the gallery but there was some error so I will try agian later.
Old May 1, 2006 | 08:29 AM
Fullcrew7.3's Avatar
Fullcrew7.3
I never did the zoodad. Did it help much? That's the fresh air one right? Actually, I don't remember what the CCV is anymore either.
Did you notive a difference in the turbo whine with the kwik filter? It spools up quickly don't it.
Old May 1, 2006 | 10:31 AM
Corner Gas's Avatar
Corner Gas
I did the all 3 mods at once so I can't tell you if the zoodad made much difference but alot of other guys said they noticed a difference and it was easy to do. It is just plastic so it took about 30 seconds with the angle grinder with a cut of wheel, then just touched it up with a dremel tool. By the way, the zoodad is the fresh air one, and the ccv is the crankcase vent. As for the zoodad I can see the air filter from the front of the truck now so I would think it is getting more air. The turbo definitly spools up faster now, very nice.
Old May 1, 2006 | 02:40 PM
66gpw's Avatar
66gpw
You have Puffy Mid section too. I'm inflicted with that also. It's hard carrying a kegger there instead of a six pack.
Old May 1, 2006 | 09:55 PM
Corner Gas's Avatar
Corner Gas
I am still in good humor though and I have'nt cried at all, well maybe once when I peeled all the skin of the knuckle of my thumb. But, Amy doctored me up and I have a nice Cinderella bandage on it know so everything is fine now.
Old May 2, 2006 | 12:17 AM
preppypyro's Avatar
preppypyro
Good to hear the mods made a difference
Old May 2, 2006 | 10:19 AM
Snowking's Avatar
Snowking
Man I'm out of date, the parts I can tell are too new for me.
Old May 2, 2006 | 02:42 PM
Fullcrew7.3
I may be doing some tranny work on mine right away. The syncros were gone out of 3rd when I got the truck and I've had it over a year now. Time to fix 'er up.
Then the pyrometer.
Old May 2, 2006 | 07:55 PM
Corner Gas's Avatar
Corner Gas
I would like to get some gauges before I start doing much pulling.
Old May 3, 2006 | 12:15 AM
preppypyro's Avatar
preppypyro
What exactly does a pyrometer tell you? Exhaust temp..??
Old May 3, 2006 | 09:15 AM
51dueller's Avatar
51dueller
It tells you how close a guy from PA is to the truck and sounds a warning when near.
Old May 3, 2006 | 12:49 PM
Fullcrew7.3
51dueler is the king of slams! I bow before your presence!
That was so totally sweet. I nearly blew a nut laughing at that one.
It's actually for exhaust temp. If the PSD exhaust temp stays over 1200F for any length of time, the pistons begin to soften (as well as other things) and you could blow the engine. Apparently this can even happen with a stock truck if worked REALLY hard.
Old May 3, 2006 | 05:07 PM
Corner Gas's Avatar
Corner Gas
That was a good one.
Old May 3, 2006 | 06:22 PM
preppypyro's Avatar
preppypyro
Funny guy I need to find me an pyro stealthmeter to combat that then
Old May 4, 2006 | 10:21 AM
Fullcrew7.3
You may have to go to a specialty shop to find that one Pyro.
