disc brake conversion
Old Jul 4, 2002 | 03:30 PM
rjhuey's Avatar
rjhuey
I have 72 F100 I am switching from manual brakes and steering to power brakes and steering.My donor truck is a 79 F150. I read in a Tech Article on this site it said to use king pin set for your truck. I compared kin pins for the two trucks and found that the pins for my 72 are 1 ten thousandth smaller in OD and 200 thousandth shorter. Is going to cause a problem? Any info would be appreciated.Thanks
Old Jul 4, 2002 | 05:10 PM
jowilker's Avatar
jowilker
If your donor front end is in good shape, you can change out the complete I-beam set, and do it faster in a lot of cases than just changing spindles. If the King pins are bad, it's a different story.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Jul 5, 2002 | 09:00 AM
evans's Avatar
evans
Use the entire front suspension from the '79 even if the king pin are worn. With the I beams off you can have the king pins pressed out. I personally wouldn't go to all the work of the swap w/out replacing the king pins anyway. If your budget allows, replace EVERYTHING. Steering linkage, calipers, brake lines etc. You can do the whole thing for about $400. Your truck will drive like new, you'll know it's right and will last.
Mike
Old Jul 5, 2002 | 02:09 PM
rjhuey's Avatar
rjhuey
I was going to use the I-beams off th 79 the truck was hit in the front and the beams are both bent. Any other advise?
Old Jul 5, 2002 | 05:34 PM
jowilker's Avatar
jowilker
It would have helped if you had told us in the first post.
John
jowilker email me
Old Jul 5, 2002 | 06:28 PM
jalopy45's Avatar
jalopy45
