Sponsored by: Auxito
Vibration problem. . . Need advice
Old Apr 30, 2006 | 06:02 PM
Nate27's Avatar
Nate27
I got a 98 150 4.2 V6 that hyrolocked on me, so I got a remaned and I put everthing together and got it back in and everything is running great. But there is a slight vibration that you can feel in the drivers seat while the motor is at an idle. Everything sounds good but the slight vibration has me worried. The only thing I can see is that the crankshaft pully that runs the belt is bent slightly. I know that the crank isnt bent because the balancer that the pully bolts on to runs true. I just dont think that that little belt pully being bent a little bit would make the whole engine vibrate like that. I was wondering if that motor is out if time slightly to cause that. If you guys I have any suggestions or have had a similar problem I would love to hear because I have run out of ideas. Thanks a TON!!!
Old Apr 30, 2006 | 09:02 PM
LxMan1's Avatar
LxMan1
You may want to try cleaning the injectors if they came off of the original engine. Does it go away above idle? Are the plugs, wires and such new?
