Interior painting?
Old Apr 30, 2006 | 03:12 PM
F250FarmBoy's Avatar
F250FarmBoy
Interior painting?
Howdy,
How do I paint my interior plastic? I'm going to paint the truck black and want a matching interior. Is it easy or hard to do? Do they make a product especially for this kinda project?
The old color was blue, and it might look good w/o altering the interior color, but like I said before...I want a matching exterior/interior.
I'll install a black vinal floor and re-do the seats.
Old Apr 30, 2006 | 04:25 PM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
They have textured vinal covering, and I think that's what you'd want to look into. Plastic and paint aren't the best of things.
Ryan
Old May 1, 2006 | 05:10 PM
Rocket Racing's Avatar
Rocket Racing
Old May 29, 2006 | 08:56 AM
Monarchfootbal77's Avatar
Monarchfootbal77
Krylon makes a Fusion paint... made specifically for plastic. I worked at an Ace Hardware... thats how I know about it but I haven't heard anything about it really. I guess it depends how willing you are to try something. Just make sure you prep it right and it will stick.
Old May 29, 2006 | 11:25 PM
FghtinIrshNvrDie
I sell that stuff at Westlake ACE Hardware too. I'm not sure what kind of the results the customers are getting. No news is good news?
Ryan
Old May 30, 2006 | 08:19 AM
sandhillmike's Avatar
sandhillmike
I have used SEM vinyl dye with excellent results. Get it at any auto paint supply. You can get it in spray bombs or bulk. They can also mix custom colors.
Old May 30, 2006 | 06:15 PM
steve66's Avatar
steve66
Hey Farmboy,how's it going?I have done the same thing a few times,and what you need is called vinyl dye.You can get it in spray bomb or use an additive in a spray gun.Just remember to wipe ALL of the plastic down with a solvent,such as acrysol,which works the best,or laquer thinner before you start to paint or the paint will more than likely ''fisheye'' or seperate very badly.Be very carefull if you use thinner because it IS very flammable and the fumes aren't good for ya either.Other than that,just tape off what you don't want to paint and have fun!
Old May 30, 2006 | 08:20 PM
F250FarmBoy
Thanks for all the pointers guys. This idea is in the back of my mind right now cause I'm fixin my axleshafts now, which shouldn't take long, but everything takes 3x longer than it should be at my house. Hopefully i'll get this done before school next year.....Thats a BIG hopefully. lol
Keep chug-a-luggin.
FarmBoy
Old Jun 1, 2006 | 10:12 PM
fozzy's Avatar
fozzy
If you are talking about those rigid plastic seat belt retractor covers, you can paint them with whatever you use on interior/exterior. The plastic has to be prepped properly. I just did some with a light blue, then I cleared them. I used a coat of urethane 2K primer first then sanded to 220 grit. You want to use a medium reducer in your base coat so it flashes quickly. The factory painted them so I dont know why you wouldnt be able to.
As far as the vinyl, I got fed up with the poor selection of colors available from SEM. There darkest blue looked like powder sky blue. So I covered the SEM with a krylon exterior trim paint. It is more flexible like an epoxy and it has the semi-gloss sheen that I wanted. I used it on the dash pad and it looks great. I did have a base of the SEM powdery stuff so I would imagine that helped hold it on and give it a good base.
Good luck!!
Old Jun 3, 2006 | 07:03 AM
mississauga's Avatar
mississauga
I have used SEM with good results. As some of the other posts have said prep of the parts is important for a lasting job. I used acetone to clean and wipe all the parts down. Add it to the rag first then wipe you parts. You could melt some parts if you get crazy with the stuff.
phoneman91
Paint & Bodywork
Apr 28, 2016 07:59 AM
429poweredf350
Apr 20, 2011 11:53 AM
phoneman91
Jul 21, 2009 06:08 PM
lzrj
Jan 6, 2009 08:56 AM
supermanpsd
Mar 22, 2007 05:28 PM
