Computer Chips & Tuners
shifting = HARD!
Old Apr 30, 2006 | 12:39 PM
nugent_crai's Avatar
nugent_crai
shifting = HARD!
I used a superchip to reprogram my shifting points and rev limiter. The problem is when i give it a little gas, when the truck shifts from 1st to 2nd it JERKS HARD. it feels like you would have dropped the clutch if i had a manual. what can i do to fix this?
thanks in advance
Craig
Old Apr 30, 2006 | 05:03 PM
toddyw's Avatar
toddyw
Have you given your truck enough time to "relearn" its shifting. If I remember correctly it takes 5-6 cold starts for the computer/transmission learn the new shifting program.
Old Apr 30, 2006 | 05:05 PM
nugent_crai
i have put over 8,000 miles on it since i superchipped it. It has been doing it since day 1.
Old May 2, 2006 | 12:22 PM
MotorHaven Guy's Avatar
MotorHaven Guy
What vehicle is this on?
Old May 2, 2006 | 12:24 PM
nugent_crai
a 2004 F250 superduty 5.4L gas
Old May 2, 2006 | 12:27 PM
MotorHaven Guy
Okay, on that vehicle you ought to be able to use the Superchips tuner to soften the shifting on a gear by gear basis. If it were a diesel you'd be out of luck. It should be covered in the user adjustable parameters.
Old May 2, 2006 | 12:29 PM
nugent_crai
oh boy, that sounds like alot of work.. and something that I could easily mess up...haha.. ill look into it.. thanks
