Tail Light Problems !!!
Old Jun 28, 2002 | 06:22 PM
IBen17's Avatar
IBen17
I have a 68 F100 and I am putting a wooden bed on it. I am having problems with the taillights though. I reconnected the factory taillights the same way they were on originally. When i tested them this is what happened
Turn signal- front, and rear lights turn on but do not blink, arrows on dash do the same
Brake-no response
Headlights- front work no response in the back
Back up lights no response
I really would appreciate it if someone knows how to fix this problem.
Thanks...I hope
Old Jun 28, 2002 | 07:40 PM
barry's Avatar
barry
Were they working before? Do you have the tail lamps grounded to the frame? When you removed the old tail lights from the pickup body, was there a short wire attached to the light body by a small screw? If so, you need to attach that wire to the light body and run a jumper from each light to a clean ground on the frame. Chances are the electricity has nowhere to go without a ground.
Old Jun 28, 2002 | 08:17 PM
1968F250LWB's Avatar
1968F250LWB
Definately agree with above post. It is definately a ground. If you get them grounded correctly and the blinkers still perform the same way it is most likely the flasher. A good test for this is to turn on your emergency flashers. If it does the same thing it is most likely the blinker flasher that is bad. Or it could be both flashers are bad but that is a long shot.
Good luck,
Russell
1968 F250 LWB 300-6
FORD=First on Race Day
MOPAR=Mostly Old Parts and Rust
Old Jun 29, 2002 | 08:29 AM
IBen17's Avatar
IBen17
Hey thanks I think its the ground
I will try that tonight or when i get a little time
Old Jul 2, 2002 | 10:29 AM
xericx's Avatar
xericx
[updated:LAST EDITED ON 02-Jul-02 AT 11:31 AM (EST)]xericx
If nothing else works try a directional switch,I had the same probelm with my '72. I got lucky and found one at a ford dealer ship only around 200 miles from my house.
Old Jul 8, 2002 | 04:12 PM
F100NIGHTMARE's Avatar
F100NIGHTMARE
Old Jul 9, 2002 | 09:19 AM
IBen17's Avatar
IBen17
It was just the ground. I went ahead and completely rewired the lights and tailights on the truck while I was working on it.
