need help
Old Apr 30, 2006 | 08:57 AM
edward327's Avatar
edward327
Question need help
My stock 96psd does not seem to have as much power as it should. I drove a 2000 and there were no comparison. I have 4:10"s, changed the fuel filter, air filter, recently changed the cps and glow plugs last year. 120,000. miles. It has a blue/white smoke on startup sometimes, especially after sitting for several says. It is also hard to start sometimes for the first start in the am. I checked the hpop resivour and it is always full. All the glow plugs ohm out at .005 to .006 through the harness. I have never checked the relay though. Any help would be appreciated. There is so much info here it is hard to sort through it all.
Mike.
Old Apr 30, 2006 | 11:32 AM
DaBigTow's Avatar
DaBigTow
Glow plug relay would impact starting, but not running performance. If your voltmeter drops a bunch after you turn the key on, the GPR is working. I'm not surprised that there would be a noticable difference between a '96 and a '00; bigger injectors & all.
Old Apr 30, 2006 | 12:03 PM
1997F-350's Avatar
1997F-350
what kind of mods does your truck have?
fwiw sd injectors are a lot bigger than a stock 94.5-97 truck.
i suggest you do a few mods and wake that thing up.
Old Apr 30, 2006 | 03:09 PM
14psd's Avatar
14psd
I would also chech the GPR. I have a '95 that WAS a pooch until I did the exhaust. That will make a big difference. My '95 now will move now with the few mods. It will out run/pull my buddy's stock '01 psd. If it still doesn't have the power you're looking for after you do the exhaust consider some other mods.
