351 H. O.
Old Apr 29, 2006 | 08:02 PM
dnmccy1's Avatar
dnmccy1
351 H. O.
i'm going to rebuild my 351 windsor high output so can i use a master rebuild kit or is there something different that i need
Old May 19, 2006 | 11:57 AM
dnmccy1's Avatar
dnmccy1
Red face vaccum problem
Iwas just wandering has anyone heard of having a vaccum leak that caused an engine to run hot . any help with this will be greatly appreciated Thanks
Don McCoy
Old May 19, 2006 | 03:03 PM
HardCore Dawg's Avatar
HardCore Dawg
High Output?......what makes it a HO?....I'm going to build one too.....just picked up a F250 with a 351W and auto tranny for $300 (beatup work truck) I'm going to rebuild the engine and tranny and swap out my 302 and std.
Old May 19, 2006 | 04:31 PM
dnmccy1's Avatar
dnmccy1
the only thing that makes it an h.o. is that it came with a 4 barrel carb and dual exaust from the factory it might have a different cam in it as well it was a marketing thing from ford
Old May 19, 2006 | 09:44 PM
downhillpat's Avatar
downhillpat
Actually, the HO is only a 4bbl carb...not dual exhausts. My 87 "was" the same setup. Until I swapped out the holley 4bbl for an edelbrock 1406
Trust me..ditch the holley 4bbl...it was garbage.
Old May 19, 2006 | 09:49 PM
pfogle's Avatar
pfogle
It also has a bigger cam, turn your idle down to about 500 rpm and you'll hear it lope a little. Its basically the same cam that the EFI motors got in '88
