I have a '71 F100 with a 390. I just changed the valve stem seals because it was smoking a bit on start-up. Under the valve covers there was a little bit of sludge and quite a bit of carbon build-up. There was even an oil drain passage clogged on one side, which I cleared. Before putting it back together I shop vacced the worst of the flaky carbon pieces.
My question is: Has anybody flushed there engine oil system with flushing additive (that five minute stuff)? How did it work for you? Where there any bad side effects? What are the pros and cons of using it?
My reason for that is I have seen several instances where someone put something in the oil (kerosene, a commercial flush...etc...) and thought they were helping to prolong their engine life, only to see oil leaks develop,(old dry caked oil often forms a seal)
I have also seen instances where someone threw a rod, because basically all the old crud was loosened a bit(but didnt come out right away in the flushing process) and eventually worked out later, disolving into the "fresh oil" and of course gunk is abrasive so you know how the bearings loved that.
[updated:LAST EDITED ON 11-Jul-02 AT 10:19 PM (EST)]If you would really like to flush the engine, he best thing to do is remove the pan, clean it, and clean the oil pickup tube screen. While you're at it, change the rod bearings for longer life.
It isn't hard to do, but there are few little details good to know that will help you avoid little headaches.
Drew is right on the money: DON'T use those engine flush treatments!
Yup, flushes are no good. We used a flush once on a '66 F100 with a 240 cu.in. six. Shortly after that the rod bearing noises got unbearable. The front sheetmetal was rotted anyway, so it wasn't worth rebuilding. We turned it into a trailer shortly after that.
