adjust speedo?
adjust speedo?
i have a 1975 f250 camper special with a 460/c6 trans, and when i bought it the guy told me that because the rear tires are so bigger than the stock tires that when im going 40mph im really going 30, and when i go 60 im really going 50...and so on. is there a way to change that so my mph is my acutual mph?
You need to change the speedometer gear, and the best way to do that, would be to go to broncograveyard.com
They have a calculation that can tell you which gear you need, and they sell all different kinds for a few bucks.
Or you could always change the gears in your axle, and then the truck would have better accleration, get better gas mileage, and correct the speedo.
I posted the the exact same thing you mentioned one post above yours.
A speedo gear calculator
im not sure exactly its a pretty new truck for me, when i get home i'll measure. do i measure the outside diameter of my rim, or bottom of tire to top? also when i bought the truck the guy said it was pieced from 5 different trucks. whats the like ability of the gears ratio on my door to be the same in the axle?
Are the tires sizes metric? 285/75R15 or somthing like that, b/c if it is that size in the rear then they are 32" tall and 11" wide.
If the tire size is only about 32"tall, then your cheapest and best suited fix would be a new speedo gear.
BUT if you have the money, switching gears to about 3.73 would help acceleration and mileage a little bit.
There is a number or letter on the driverside door jam that Mil1ion can help you out with if you need, or they have a metal tag on the rear bolt circle with numbers and letters on it, and if you get back to us on here with either of those we can let you know what gears came stock in the truck.
