rag joint worn out
Old Apr 29, 2006 | 04:54 PM
DouginTahoe's Avatar
DouginTahoe
rag joint worn out
I need to replace mine on 1992 Explorer. Flaming RIver sells a U joint replacement product- getting rid of the rubber piece altogether. anyone out there have to do this ?
thanks !
Doug
Old Apr 29, 2006 | 08:08 PM
marragtop's Avatar
marragtop
Can you be more specific as to what you are trying to do?
Old Apr 29, 2006 | 08:24 PM
amish77's Avatar
amish77
getting rid of the rubber will eliminate the thing wearing out, but it will also give you a bit more shaking through the wheel, from the tires. If you think this will bother you then maybe the rubber isnt all that bad.
Old May 1, 2006 | 10:43 PM
DouginTahoe
rag joint replacement...
I am basically wanting to either replace the rubber disc it self ( steering coupler ) or remove it altogether and go with a u joint. Just want to know if anyone has done this. I put a 3 inch lift on the truck and the angle stresses the rubber and causes it to crack - rip - tear. Eventually it will tear apart and no steering is dangerous.
Old May 3, 2006 | 07:40 PM
amish77's Avatar
amish77
hey I'm with ya. I'd rather not have mine either. If the shaking won't get on your nerves, then go for it.
DOUG5G
Aerostar
18
May 11, 2011 02:27 AM
dougsbart
Sep 13, 2007 03:00 PM
douglee25
Jun 14, 2007 02:45 PM
dougg
Mar 3, 2003 09:18 AM
ke4vbg
Dec 15, 2002 09:58 PM
