worried
Old Apr 29, 2006 | 04:11 PM
4xsport03's Avatar
4xsport03
worried
I just purchased a 2006 crew cab 4x4 sport F250 w/ PSD yesterday. It has just over 600 miles on it and now I'm noticing oil drops on the driveway. My question is I guess, is this a bad thing or a normal thing? This is the first diesel i have ever owned so I have no clue as to if this should be happening or not. Any info will help.
Thanks
Murf
Old Apr 29, 2006 | 04:50 PM
mschultz's Avatar
mschultz
Take it back right now.
If the leak is a minor accessory leak, no big deal.
If the leak is from rear main on the engine, do everything you can to return the truck and start over- You really do not want to start off with a new truck that has been butchered by the local service department.
Step one- figure out where it is comming from. It may be very minor.
Step two- figure out if you want it fixed or if you want to try and change trucks.
In my state, buyers have a window of a couple days to change their mind and return their vehicle. I see no reason to have $30k+ tied up in a new vehicle that leaks.
Old Apr 30, 2006 | 08:44 AM
pamelbert's Avatar
pamelbert
Very simple, take it back!!! Minor or major, a new truck shouldn't leak.
Old Apr 30, 2006 | 09:28 AM
kw5413's Avatar
kw5413
Welcome to FTE and the 6.0 Forum 4xsport03
When you get a chance check out our 6.0 Tech Folder
https://www.ford-trucks.com/forums/s...d.php?t=303583
Definitely, if your leak is hitting the ground get right back to the dealer.
Old Apr 30, 2006 | 10:07 AM
deacjrt's Avatar
deacjrt
As they said, return it. I have an '04 with 50,000 and have never seen any kind of an oil leak.
