Different day same old stuff!!!
Old Apr 29, 2006 | 08:09 AM
ercaraker's Avatar
ercaraker
My '94 F-150. 302 with E4OD has After many repairs and services I have what I believe was my original problem all over again. I started out several months ago with loud noise which sounded as though it came from under the hood at high speed, I first noticed it on a long interstate trip. It happens when I hit passing gear at lower speeds and at about 65-70 mph when I shut down the O/D. Sounds like a plane prop. I have had my driveshaft rebuilt and balanced, as the carrier bearing was going out. I have added Ford friction modifier to stop TC shudder which it did almost immediately and everything was fine until abouot 3 wks. ago when I had my water pump replaced. The truck runs great and mpg is averaging close to 14-15. Someone suggested the fan clutch, another said it could be either the smog pump, a/c comp. or p/s pump. Finally someone said the TC could be going bad and there are TSB regarding vibration in higher mileage trucks like mine. Any Information would be greatly appreciated. Emmett
Old May 5, 2006 | 05:12 PM
ercaraker's Avatar
ercaraker
Different Day Same old Stuff
I mistated my trans. type but since noone responded to my posst it's no big deal. I visited the transmission shop today and the owner took my truck for a drive. He said the Torque convertor and transmission are working perfectly. So now I am back where I started last fall. The noise/vibration is comiing from the engine or something running off the belt. How does one test the vibration damper?
1L243
May 16, 2010 11:38 AM
F350_Hauler
Jul 3, 2007 09:37 PM
ernesteugene
22
Mar 13, 2007 02:48 AM
jtharvey
Jan 9, 2006 07:15 PM
