Sponsored by: Kumho
rear spring block help
Old Apr 28, 2006 | 02:22 PM
tastyklair's Avatar
tastyklair
I had to put new rear springs on my 79 F150 4x4. The ones I put on were listed as a heavy duty but supposedly stock dimensions. After putting them on I had to fully extend the rear shocks and even then coax them to get them on. My trick has 3" blocks on the rear spring perches. I don't know if these are original or if someone added them before I owned the truck. If I remove them to get the ride height down can I bolt the springs right to the perches or do I have to have at least some smaller block on there?
Old Apr 28, 2006 | 03:25 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
that is a factory installed block, removing it will be a good thing(less axle wrap) but you will have to get some shorter u bolts, ubolts for a 2wd truck with no blocks should work
Old Apr 30, 2006 | 05:14 PM
thesprocket26's Avatar
thesprocket26
get the block out!
