Ref. Rattling knocking noise
Old Apr 27, 2006 | 11:08 PM
jcjhome's Avatar
jcjhome
Well I am back with more info. My truck is a 1990 f350 was a box truck now a flat bed. Has 143000 miles on it. Have a c6 tranny 4 speed with overdrive. has oem muffler system,seems to be in good shape. there is very little smoke if any. just smells like diesel exhaust. The rattling and knocking is more prevelent at start up and after running for about 5 min. the engine noise quitens drasticly. I have cleaned the fuel tank and added power diesel cleaner. after running for a few miles today nocking noise has subsided some but still has a pronounced nocking as driving without a load or coasting , no pull or drag is when the noise is worst. At high speed under some load engine is strong and quite..Does have a loaping or shaking at idile.
Also can find no oil leaks or water leaks. Starts very easy. Hope this will be enough for someone to give me an idea if i should be worried or just drive and enjoy..If i turn the radio up the noise doesent bother me..
I have driven gas engines all my life and maybe just not used to a diesel.
Thanks Jerry
OK I forgot to state it is an International 7.3..
Thanks and I am so glad to have found thise site and am glad to be here. Thanks again Jerry
Old Apr 28, 2006 | 09:01 AM
PLC7.3's Avatar
PLC7.3
Here is some info that may help clear up some confusion....... this is for 93 so Maxi fuse is not on your truck but similar procedure.......
How The Circuit Works
The Glow Plug Control circuit applies power to the Glow Plugs, which heat the combustion chambers so that the diesel engine can be started.
Glow Plug Controller
The solid-state Glow Plug Controller, attached to the top of the engine block, controls the Glow Plug pre-glow and after-glow time. It also controls the circuit's operation by sensing engine temperature, Glow Plug voltage and after-glow voltage from the start/run circuit.
When the Ignition Switch is turned to START or RUN, voltage from Maxi-fuse K is applied through the Glow Plug Controller to the Wait-To-Start Indicator Lamp.
The Glow Plugs heat up in zero to fifteen seconds, depending on engine coolant temperature. After the Glow Plugs heat up, the controller cycling switch opens and turns the Wait-To-Start Indicator Lamp off. The Glow Plugs are now warm enough for the engine to be started.
At the same time the Ignition Switch is turned to RUN, voltage from Maxi-fuse K is applied to the after-glow timer (located inside the Glow Plug Controller). The after-glow timer cycles the Glow Plugs for up to two minutes, depending on engine temperature. The after-glow timer then opens. The Wait-To-Start Indicator Lamp will not light during the after-glow period.
If the Ignition Switch is turned OFF, it can be turned to ON immediately, and the Glow Plug heating cycle will start again.
Diesel Start/Run
The diesel engine uses two batteries to provide extra power for starting and glow plug heating. Power is applied from the batteries, through heavy gauge wires, to the Starter Solenoid (located in the Starter Motor assembly). When the Wait-To-Start Indicator goes out, the Ignition Switch can be turned to START.
With the Ignition Switch in START or RUN, voltage is supplied to the Fuel Heater, Fuel Shutoff Solenoid, and the Engine Temperature Switch through Maxi-fuses K and U.
The Fuel Heater is in the Fuel Filter/Separator. It heats the diesel fuel, melting any wax that might clog the filter. The heater has an internal thermostat to turn it on as needed.
The Fuel Shutoff Solenoid controls the flow of fuel into the injection pump. With the Ignition Switch in START or RUN, the Solenoid is energized, and fuel is allowed to flow into the injection pump. When the Ignition Switch is turned off, the solenoid is deenergized, fuel flow stops, and the engine stops running.
The Engine Temperature Switch provides voltage to the Cold Timing Advance Solenoid and the Cold Idle Solenoid. When the engine temperature is below 112 °F (44 °C), the Engine Temperature Switch is closed. When the Ignition Switch is turned to START or RUN, the solenoids are energized, advancing injection pump timing and engine idle, allowing the engine to run more smoothly when cold. When the engine temperature reaches 112 °F (44 °C), the Engine Temperature Switch opens. This denergizes the solenoids, returning the timing and idle to normal.
To start turn key on press fuel pedal to the floor, then if above 30*F hold at 1/2 throttle, if below 30*F hold at 3/4-full throttle start engine. Once started release the fuel pedal to the fast idle setting or feather pedal to keep running.
Old Apr 28, 2006 | 11:29 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
What you have is the "typical" normal diesel rattle/clatter when cold. Hope this helps. By the way use a good grade of fuel and oil (CI-4 rated) don't use one that says for gas engines. This might prove disasterous.
Old Apr 28, 2006 | 12:23 PM
jcjhome's Avatar
jcjhome
Thanks Guys this is a big help. Also the more I run it the better it gets. Thanks a million..Jerry
