check engine help!!
Old Apr 27, 2006 | 10:04 PM
motorsportluvr's Avatar
motorsportluvr
check engine help!!
Hello all. I have a 92 f150 with 6 cyl engine 5 speed my problem is the check enine comes on right after i start to drive and i can feel a hesitation when it does the truck has been cold natured wanting to die untill it warms up this morning i cranked on her for 10 minutes and finnally i rolled it off and it started after about 25 feet and started fine the rest of the day even after it had set for 6 hours. when i bought it someone switched to points and i put it back to electronic and changed plugs wires fuel filter and still have the problem..any help will be greatly appreciated....
Old Apr 27, 2006 | 10:24 PM
handyman43358's Avatar
handyman43358
Welcome to FTE. Pull the codes. If you go to www.fordfuelinjection.com, on the righthand side is a link that says "Pulling the codes yourself", or something to that affect. All you need is some wire, a pad of paper and a pen. Pretty easy to do. Thats the only way we are going to be able to help you.
Old Apr 27, 2006 | 11:22 PM
motorsportluvr
ok the way i understand it the sti should be a single pin plug my truck has the 6 pin triangle box and directly behind it is a round plug with 2 round pins after you remove it from the cap and below it is a square one hanging with a gray cap it has 2 female looking plugs in it i dont want to connect to anything being unsure my luck i will burn up somthing also i just noticed that the vaccum line to what i assume is the egr was unplugged and a screw was used to plug it and on the egr nothing just the bare nipple where the line would go no plug off on it maybe the guy i bought it from was to tight to buy one so that may be my problem i will plug it up ofcourse and see what happens tommorow. I really cant complain it runs great and drives better the body is perfect except for som paint fade and i got it for $800 bucks but i would like to resolve this problem as i think it may be robbing some power..
Old Apr 28, 2006 | 12:20 AM
motorsportluvr
ok i got the code all i get is a 522 and an 11 the first time i had it in gear so i went back and did it in neutral and still 522 and 11
Old Apr 28, 2006 | 04:33 AM
motorsportluvr
Ok i got it it turns out the guy sold it to me i guess because he couldent figure it out he replace almost everything including the relays well by reading these thrads i decided to test the fuel pump with the eec test ground and it dident work so i changed a relay still nothing so i noticed the pins were corroded after cleaning them it tested fine now it has twice the power and runs like a new truck..This forum is great...
Thanks for all the help guys.................
Old Apr 30, 2006 | 12:13 PM
handyman43358
Good deal! Glad to hear it!
