For Subford, Andym...Engine Computer
Old Apr 27, 2006 | 04:10 PM
Dusty Roads's Avatar
Dusty Roads
Question For Subford, Andym...Engine Computer
Gentlemen,
I'm interested in getting a spare engine computer for the Blue Goose before they are really hard to get. ... '91 F150 Lariet Ext Cab, 4.9 L6,E4OD. 3.55 2WD.
So I saw a computer on EBay that matched my specs. except for a 5spd. and 4x4. Question is ... How close do the truck specs. need to match up with the computer in order for it to work properly?
Thanks, DR in Dallas
Old Apr 27, 2006 | 04:30 PM
andym's Avatar
andym
You're way off.
You need a computer that will control both your straight six and your E4OD. The tranny is electronic and needs to be controlled by a computer.
Honestly, I wouldn't worry too much about the computer. It's rare for one to go out. It does happen, but not as much as people think. Most of the replacements are done by mechanics who can't troubleshoot well and just start replacing components at random hoping to fix the problem.
Your computer will probably outlast the truck.
But if you really want one, keep looking. You'll find one eventually.
Old Apr 27, 2006 | 06:11 PM
subford's Avatar
subford
Originally Posted by Dusty Roads
Gentlemen,
How sure are you that you have an E4OD Transmission?
The guide I am using does not indicate an electronic Transmission behind a 4.9L in 1991, I was thinking you may have an AOD. If so the computer may work for you but if you truly do have an E4OD then keep looking as andym said.
Old Apr 28, 2006 | 11:59 AM
Dusty Roads
AndyM,Subford ...
Thanks for the input ... The E4OD checks out on the door label and the gear selector display. Your point about the EEC needing to be configured to control the E4OD is certainly correct ... Good thing I didn't choose auto mechanics as a profession! You all are probably right about the computer lasting longer than I will ... But I'll keep looking for a correctly configured EEC.
You all always have good information on how to keep these old trucks running.
Best Regards, DR in Dallas
