oil pressure
Old Apr 27, 2006 | 03:04 PM
inline6 Red Neck's Avatar
inline6 Red Neck
Red face oil pressure
when i got my truck the gauge read no oil pressure the i ran motor flush through it and i gave me normal oil pressure then i started it up today at first the oil pressure was good then 10min letin it idle the gauge went all the way to the L for low is my oil pump bad or the sending unit?
Old Apr 27, 2006 | 07:53 PM
grclark351's Avatar
grclark351
get yourself a mechanical gauge and see what it tells you. could be the stock gauge and/or sending unit? some replacement sending units are not calibrated correctly, or there are different calibrations.
could be a clogged pick-up screen? most times flush will make more problems than it fixes, usually the crank bearings are gone rather than the oil pump .
