1978 - 1996 Big Bronco
need electrical help - 1979 bronco
Old Apr 26, 2006 | 01:11 PM
fords_forlife's Avatar
fords_forlife
hi this is my first time posting in this forum. i have a '79 bronco that the rear window is really stumping me right now. It wasn't working when I bought it but between me and my brother we got it working. But then my brother trusted a friend to install a radio and run speakers and since then the window doesn't work. i looked at what he did for the radio wiring and it was a rat nest so i cut all of that out and now am trying to get the window to work agian. this is what i know so far...
There is no power to the switch in the dash.
Cut wires, a blue and a yellow wire (i believe these were for the radio as the blue is illumination and the yellow is 12v power) also two wires cut about 10" up from the hi/low beam switch which i believe go to the door buzzer.
All fuses in panel are good except for the one in top row all the way to the right, i'm not sure what it is for but there is no power to it.
any help in pointing me in the right direction would really be great
FORDS_FORLIFE
