Sponsored by: Real Truck
Gear pricing
Old Apr 26, 2006 | 01:09 PM
kimminau2's Avatar
kimminau2
Gear pricing
I am seriously thinking about going from 4.10 gears to 4.56's in my 06 F250 4x4 KR V10. I do not know what would be a "normal" price to expect for this swap.
I got a guestimate from a local and well respected truck shop of +/-$1,200 per axle.
CAn anyone provide any insight on this estimate? BTW they would be using Dana gears.
Old Apr 26, 2006 | 01:19 PM
mwpierson's Avatar
mwpierson
Wow! That's way too much. Are you sure it's "per axle?" Expect to pay $1200 to $1500 for BOTH axles.
I had my 02 V10 done for $1500 (front/back) out the door. They were also Dana gears; 3.73 to 4.30.
Mike
Old Apr 26, 2006 | 01:26 PM
kimminau2's Avatar
kimminau2
I will check, maybe I misunderstood. That would make it much easier to swallow.
Old Apr 26, 2006 | 01:28 PM
mwpierson's Avatar
mwpierson
Forgot to mention: There was a thread about this a year or so ago. The consensus was around $1500.
Mike
Old Apr 26, 2006 | 07:34 PM
mattd17's Avatar
mattd17
yes, i also looked around myself, and it was between 1200-1500 for both axles. the actual parts are fairly cheap... really only run you about 400-600 dollars for the gears with the master install sets... its the labor that kills ya on this job !
Old Apr 26, 2006 | 11:56 PM
skinner00's Avatar
skinner00
i had a local shop (one man shop) do mine, he charged me 1700 for both axles. i was happy, i actually met the person working on my truck and he had a great reputation
Old Apr 27, 2006 | 09:25 AM
mwpierson's Avatar
mwpierson
Yes... make sure you go with somebody who has a good reputation. I followed word of mouth to the shop that did mine. Had it done quickly, neatly and backed his work with a one year warranty.
Mike
Old May 2, 2006 | 05:25 PM
kimminau2's Avatar
kimminau2
You guys were correct. I had misunderstood and it was $1,200 total. However I think I have decided to go with 4.88's and the new price is $1,500.00. The big difference is they actually looked at the truck.
Old May 2, 2006 | 05:39 PM
mwpierson's Avatar
mwpierson
Cool! However, you do realize that once you go to a gear that size, you'll need to stick with 35+ inch tires forever! If you ever drop down to anything below a 35" tire, you will get some nasty MPGs.
Mike
Old May 3, 2006 | 12:05 AM
skinner00's Avatar
skinner00
the guy that did my gears told me he did not recommend going any more then 4:56 (on v10) or 4:30 (on diesel) i have 38's
Old May 3, 2006 | 04:12 PM
kimminau2's Avatar
kimminau2
Did he tell you why he did not recommend 88's? I am interested in all points of view.
Yes I realize I will not be able to run 33's, but how many people really back down on tire size? I know I never have, it always seems that I could fit a little bit bigger tire in there, so I do it. But point taken.
Old May 4, 2006 | 12:07 AM
schmidt64's Avatar
schmidt64
Some people have to run a smaller tire in winter, depending where you live
Old May 4, 2006 | 12:12 AM
skinner00's Avatar
skinner00
he said it makes the pinion gear teeth too small thus weak (if i understood him correctly)
Old May 4, 2006 | 09:48 AM
kimminau2's Avatar
kimminau2
I will check out the weaker gear issue. I had not heard that.
I guess when you live in Arizona you don't even think about having to change tires because of the season. Needless to say, I see your point but we don't change tires down here for the seasons.
