Sponsored by: Real Truck
trailer brake controller
Old Apr 25, 2006 | 11:34 PM
retcwby's Avatar
retcwby
Hi.....I just traded my 05 F250 5.4L for a 04 f250 6.0L much better truck if you ask me. but anyway I can't find the plug under the dash to hook up the trailer brake controller!! I found it on my 05 model plugged into the back of the pocket on the dash where the factory controller would be installed if it were so equiped.
does anyone know where i can locate it??
Old Apr 26, 2006 | 12:07 AM
99f350sd's Avatar
99f350sd
Should be close to the same area. Does it have the that option?
Dick
Old Apr 26, 2006 | 05:55 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome rectwby to Ford Truck Enthusiasts!
…..See you on the boards.
Old Apr 26, 2006 | 06:38 AM
wiingnut's Avatar
wiingnut
retcwby, If it has that option it should be in the same spot.
Old Apr 26, 2006 | 06:41 AM
missouguy's Avatar
missouguy
To the right of the steering column behind a brace. Look hard it is a bear to find. Your truck must have the towing package for it to be there.
Good luck.
Frank
