tail light problem
Old Apr 25, 2006 | 09:05 PM
mtpcage's Avatar
mtpcage
tail light problem
put the bed back on the truck, blinkers and brake lights work but i don't have any tail lights. have two wires going to each side . I am sure its an easy fix but just spent 3 hours with no result . Any help or input?
thanks again
Old Apr 25, 2006 | 09:11 PM
G'sRed99F150's Avatar
G'sRed99F150
Are using the original harness? An easy fix would be to run a new wire from the fornt marker to the rear. Electrical can be such a pain. Look for broken wires, or crappy grounds.
Old Apr 25, 2006 | 09:30 PM
mtpcage's Avatar
mtpcage
original harness, will look some more what another 3 hours.
thanks
Old Apr 26, 2006 | 04:59 AM
jowilker's Avatar
jowilker
thanks again
There are only three wires used for tail lights. Two for brake/signal, one for each side and a common tail.
I was interested in the two wires going to each side. I am wondering if one of those is your tail light.
John
Old Apr 26, 2006 | 11:33 AM
magee's Avatar
magee
You could try using a test light to verify what each wire does and also make sure that you have a good ground. I had a similar problem with a 66 Chevy truck and it turned out that I had a bad ground. Like you, I almost lost what little sanity I have left.
Old Apr 26, 2006 | 07:27 PM
jd_sylvia's Avatar
jd_sylvia
I recently replaced my bulb sockets and they only had two wires. One was for the running lights and the other was for the brake/turn signals. They rely on the socket being grouned properly for it to work. My new sockets had a terminal for a ground wire so I hooked it up and my lights look a lot better.
Good luck
jd
Old Apr 26, 2006 | 08:26 PM
mtpcage's Avatar
mtpcage
thanks i will take another look on fri , will bring the truck back to my shop the restore is 95% . only other major problem is an after market wiper motor with trying to keep the same original switch
thanks
