Sponsored by: Auxito
2003 starting problem
Old Apr 25, 2006 | 07:26 PM
uncleglenny's Avatar
uncleglenny
i have a 2003 5.4 sometimes it doesnt start right away, it turns over and when it fires it sound like it stumbles like there is too much gas not all the time but enough could it be the iac valve?
Old Apr 25, 2006 | 08:23 PM
projectSHO89's Avatar
projectSHO89
Maybe. It could also be other things, such as weak fuel pressure.
More diagnostics are defintiely needed.
Steve
Old Apr 26, 2006 | 06:13 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome glenny to Ford Truck Enthusiasts!
…..See you on the boards.
Old Apr 26, 2006 | 06:36 AM
uncleglenny
ive had a rough idle since new so from what i read i thought it could be iac valve. if it was a weak fuel pressure wouldnt it do it all the time?
Old Apr 26, 2006 | 07:00 AM
projectSHO89
Not necessarily.
You might have a clogged fuel filter that is delaying the application of full pressure.
Might also have a faulty check valve on the pump that is allowing the fuel pressure to bleed down.
Try cycling the key to RUN but not hitting START. Switch OFF. Repeat several times, they try starting. See if that makes any difference.
Try cracking the throttle while starting. If that helps, the IAC is sticking closed.
Any CEL/SES? You didn't state. If so, get codes.
Steve
Old Jun 4, 2006 | 08:16 PM
fenceguygreen's Avatar
fenceguygreen
Check when you open your truck's doors if the chime is going. Even though your lights maybe off and no key in the ignition.
wolfmanagh
Jul 9, 2012 04:40 PM
L. Roy
6.4L Power Stroke Diesel
Aug 3, 2011 04:43 AM
salesman
1983 - 2012 Ranger & B-Series
Dec 25, 2010 11:17 AM
red2003
Aftermarket Products
Aug 5, 2005 05:39 PM
blackmax
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sep 24, 2004 07:08 AM
