Update On 460 Power
Old Apr 25, 2006 | 06:25 PM
kermmydog's Avatar
kermmydog
Smile Update On 460 Power
I just want to share, that my 460 F250 4x4 C-6 3:55 gears after changing the timing chain to a Cloyes TRUE street roller and advancing it 4 degrees past TDC.
I just pulled 10,000#s 300 miles. and before on the same roads I got 4.5 MPG to 5.5 MPG. The other day I got 5.6 MPG to 6.8 MPG. That's a big difference. Again same roads same trailer, both pulls I used acetone also. I increased the acetone 1 oz/10 gals this time, The power curve was really different for the better. I pulled from Bullhead City to US 95 about 12 miles 6 percent held 45 MPH in second, before I would have to go into first at my slowest point.
Old Apr 28, 2006 | 06:58 PM
kermmydog's Avatar
kermmydog
I continually read posts wanting info on what I posted here, Sorry I wasted the space.
Old Apr 28, 2006 | 08:27 PM
monsterbaby's Avatar
monsterbaby
don't be sorry for posting your info, it's good info. You have just noticed one of the most annoying things on FTE and any other forum and that is the continues asking of the same question, but if your info stops even one person from having to ask again then it was worth the time and space.
Old Apr 29, 2006 | 12:30 AM
turbo2256d's Avatar
turbo2256d
Whats a 6% grade? How many ft above sea level was the rest of the trip flat?
Old Apr 29, 2006 | 12:50 AM
monsterbaby
to figure grade, think of flat as 0% and vertical is 100% so then you take the grade as a percentage point of bieng in between those too extremes.
Old Apr 29, 2006 | 01:17 AM
turbo2256d's Avatar
turbo2256d
so in degreess that would be 15*
Old Apr 29, 2006 | 11:31 AM
monsterbaby
no it's actuallypretty close to the same as degrees, if you figure flat at 0 degrees, and vietical at 90 degrees it's only off by 10%, so it would actually be 5.4 degrees. May not seem like much on paper but it feels like alot in a vehicle.
Old Apr 29, 2006 | 02:56 PM
turbo2256d's Avatar
turbo2256d
Just havent been anywere grades are listed on hills. Grew up mostly in PA. Wonder what sizze tires your running kermy
Old Apr 29, 2006 | 03:10 PM
Bdox's Avatar
Bdox
Twenty percent increase in milage, that's big, especially for a fairly cheap mod!
Old Apr 29, 2006 | 04:20 PM
WILDEBILL308's Avatar
WILDEBILL308
Now that you have gotten that much inprovement You may be tempted to try some outher things lol. I have ben doing some reserch and working on a 460 for my moterhome. Simular application since it will be pulling a heavey load all the time. One thing that I am interested in trying is a low stall torque converter from TCI it is supose to stall at about 1200 rpm and have less slipage than stock. I beter get back out side and get some work done rather than setting on hear .
Bill
Old May 3, 2006 | 08:05 PM
kermmydog's Avatar
kermmydog
Smile
turbo2256d, I started at 3100 ft the first of two 6% grades took me to about 5000 ft in 7 miles, the second was 12miles long I traveled from 3100 ft to 5500 ft down to 2600 ft in 350 miles. I was real pleased with how much better the truck ran not to mention the addtional mileage.
WILDBILL308, Yea, I have been looking at the tow converter by TCI in Jegs. I have to change heads one of these days because of a couple of broken exhaust bolts that are broken inside the head, I've tried heating only to spider the bolt hole. I plan to buy stock heads and clean the humps out, then go with headers. This mileage increase was with a 4160 Holley 600 CFM .622 Maxijets and 6.5 PV. BLK secondary spring.
Craig
Old May 3, 2006 | 08:46 PM
WILDEBILL308
I hav heard of people using a torch to blow out a broke bolt but don't think I would try it on my heads . I have seen the use of a ESD (electric spark discharge) machine to cut the broken bolts out but not maney places have them.
When you by headers I would recomend Thorleys as they are bilt for low end torque and that is what you need for towing.
What speed and rpm were you runing on your trip?
Bill
jdhudall
1997 - 2003 F150
Mar 27, 2012 03:40 PM
kmonty2
6.2L V8
35
Jul 25, 2011 10:27 PM
phillips91
44
May 3, 2008 09:00 AM
ckelly83
Alternative Fuels, Hybrids & Mileage
Mar 28, 2006 09:55 PM
ItsReallyDarren
General Automotive Discussion
Jul 19, 2004 08:30 PM
