Engine noise
Old Apr 25, 2006 | 05:45 PM
alpinearchery's Avatar
alpinearchery
Engine noise
I own a 92 Ford F-250 with an inline 300 .When you first start the truck there is a pecking noise but after awhile it quites down.I think its a sticky lifter .Is this something to worry about and what could I do to fix it.
Thanks guys
alpinearchery
Old Apr 25, 2006 | 06:07 PM
andym's Avatar
andym
What kind of oil filter are you using? The 300 is picky about the oil filter because it's mounted on its side. Cheaper filters like fram don't have an anti-drainback valve and will do this every time. It's really bad for the engine. You're basically running it without oil for a few seconds every time you start it up.
Get a motorcraft filter and the problem will likely go away entirely.
Old Apr 25, 2006 | 09:02 PM
handyman43358's Avatar
handyman43358
I'm with Andym on this one. I've seen the same problem and a Motorcraft filter will solve the problem.
Old Apr 25, 2006 | 09:30 PM
ForOffRoadDriven's Avatar
ForOffRoadDriven
also they sell oil filter relocation kits
