rag joint photos needed
Old Apr 25, 2006 | 02:14 PM
yellow72f100's Avatar
yellow72f100
Could someone please post some photos of an installed rag joint from several different angles. I cannot find a picture anywhere that shows me how to reinstall it on my 72 f-100. Thanks.
Old Apr 26, 2006 | 09:50 PM
jor's Avatar
jor
Here are three. I'll see if I have any others and post if I do.
jor
Old Apr 26, 2006 | 10:02 PM
jor's Avatar
jor
Here's three more: 4=column shaft collar; 6=collar loosened so can pull wheel back; 6=exposed steering gear shaft.
jor
Old Apr 27, 2006 | 01:06 PM
yellow72f100
Ragjoint "L" brackets
I am missing the two "L" shaped brackets that go on the rubber disk. Is there any place I can get just the two brackets?
Old Oct 9, 2006 | 08:40 PM
jnsnwt's Avatar
jnsnwt
Jor, Thanks for taking the time to post the pics The pics and your explanation should help make this job a lot easier for most folks.
Our '69 F-100 Explorer is different though.
Ours does not have the upper pinch bolt that is closest to the firewall. Instead I have a sleeve like ring that has two set screws set 90 degrees apart.
We have removed all the bolts from the rag joint and both set screws from this collar. We have soaked everything in penetrating oil but so far .... no joy
I cannot pull the steering wheel up more than 1/8 of an inch before this collar ring stops it dead. I need more space to R&R the rag joint. Any suggestions ?
This is a 1969 Explorer with factory ps, pb and automatic trans.
That leaves very little room for mechanic hands LOL
Old Oct 10, 2006 | 02:18 PM
dcbullet's Avatar
dcbullet
NICE headers Jor!
Mercmeister
Sep 2, 2025 11:50 PM
yellow72f100
Sep 12, 2006 06:06 PM
yellow72f100
Sep 12, 2006 12:25 AM
StockMan
Sep 2, 2001 10:47 PM
