Under Heating Problem 94 Explorer
Old Apr 25, 2006 | 01:22 PM
Repsher's Avatar
Repsher
For the past few months my 94 4.0 2x4 explorer has been UNDER heating. In cold weather I can drive at 70mph for hours with the temp guage staying on C outside of the "normal" range. In warm to hot weather it barley gets inside the "normal" range after driving for hours. 3 weeks ago I threw the belt and the temp guage shot straight up to H so I know the guage works. Is this something I should be concerned about? I'm about to drive from virginia to colorado and I'm not sure what to do. Replacing the radiator and thermostat doesn't seem that hard to do. What do you think is going on? She has 261,000 miles on her and runs great (knock on wood) should I even mess with it? Thanks
Mike
Old Apr 25, 2006 | 01:35 PM
K2JJB's Avatar
K2JJB
well... if you are running to cool I would not look to the radiator for needing replacement... sounds like you might have a bad thermostat.
Old Apr 25, 2006 | 03:19 PM
87 XLT's Avatar
87 XLT
I agree, sounds like a bad T-stat, and with the-OUCH- price of gas these days you sure dont want to be driving around in rich/open loop mode.
Old Apr 25, 2006 | 06:46 PM
Repsher's Avatar
Repsher
Thanks, I swapped out the thermostat in my 79 f-350 before, pretty easy. Is it basically the same deal for the explorer?
Old Apr 27, 2006 | 12:58 AM
Jharger's Avatar
Jharger
Maybe. Explorer has a o-ring seal. No problem changing the stat. But they usually fail on the hot reading side. I run a 180 stat in my 93 - never has a problem entering closed loop EFI operation.
Old Apr 27, 2006 | 01:32 AM
87 XLT's Avatar
87 XLT
I got fed up after getting 2 bad T-stats in a row, including the factory 192 deg that stuck shut at 5K miles.
Been running Toyota 180 deg stats since then & no more problems.
And no problem passing Calif. emmisions with the cooler stat.
Old Apr 27, 2006 | 04:47 AM
marragtop's Avatar
marragtop
Make sure you get the O-ring gasket. Some of the Tstats don't include it so you have to purchase it seperately.
