Parking Brake Sensor
Old Apr 25, 2006 | 09:56 AM
OleYeller79's Avatar
OleYeller79
Question Parking Brake Sensor
I have an issue with brake light indicator. When the ignition is in accessories position brake light indicator in dash goes on so lamp works. But it does not light when parking brake is engaged. I looked for a sensor on pedal arm, (like on standard brake pedal) but could not locate. Need to rectify in order to pass inspection any ideas.
Thanks
1979 F150
Old Apr 25, 2006 | 10:33 AM
Craigster1's Avatar
Craigster1
The brake indicator on the dash indicates the condition/position of the proportioning valve and "balance" of the hydraulic braking system not the parking brake.
I don’t believe there ever was a parking brake indicator light on your truck.
Old Apr 25, 2006 | 10:39 AM
Mil1ion's Avatar
Mil1ion
That's correct,
That is a Brake FAILURE Pressure Indicator
There is NOT a parking brake indicator on these trucks.
Next !
Old Apr 25, 2006 | 10:53 AM
tractoman's Avatar
tractoman
When is the brake warning indicator supposed to be lit? Mine only lights when I have the key in the start position and cranking.
Thanks
Old Apr 25, 2006 | 11:19 AM
76supercab2's Avatar
76supercab2
That's it. If it's on at any other time you have a failure in the braking system. This is the way it was from the factory. If your mechanic is failing you for this then you need a new mechanic. Preferably one who isn't wet behind the ears.
Old Apr 25, 2006 | 12:37 PM
OleYeller79
Talking Back to the inspectors
Great, thanks for the info. I was pretty sure I had never seen that indicator illuminate when the parking brake was in use. Now to get the inspection folks to understand.
Thanks
Old Apr 25, 2006 | 01:05 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Thanks
Well, good luck with that. Inspectors can be lunkheads at times.
Perhaps a letter from Ford would help?
All my paperwork, wiring diagrams, etc.. doesn't even show a switch or light for the parking brake, until the 1984 model year.
Old Apr 25, 2006 | 02:18 PM
76supercab2
I would ask the inspector to show you in the wiring diagram, specific to your truck, where the switch for the parking brake lamp is.
Domestic_Nuwbee
21
Nov 19, 2010 10:09 AM
6CylBill
71
Aug 8, 2010 06:44 PM
6CylBill
72
May 24, 2010 03:20 PM
lagunafordf250
Aug 6, 2008 04:55 PM
