Sponsored by: Innova
:beating head on wall:
Old May 5, 2006 | 02:25 PM
deltasoft's Avatar
deltasoft
i would either buy an amp that has for subs or buy a seperate amp 4 channel amp (kenwood or kicker) and buy an adapter that from 1 12v cable convers into two seperate ones with relay on it.....then wire grounds same way...... then everything else terminals..........
for example in my 99 f150 i have this setup:
two amps, currently a sony 4 channel for my mids and highs door spkrs, that is located under the driver's side and another amp boss to power my subs...(10"s X2) , located under passangers front seat... then i have my box on bottom of sofa on back of cab custom fit...cables all runing under carpet with fuses etc.....takes a while but job gets done well ;-) hope this helps bud!
hasteranger
Apr 12, 2012 06:58 AM
hotrod351
17
Aug 28, 2011 07:37 AM
portawatch
Jun 22, 2009 11:03 PM
IPACA9
Mar 6, 2006 07:50 AM
chamill
Jun 6, 2003 09:12 AM
