Tranny Question
Old Apr 24, 2006 | 09:35 PM
90 F-150 Hi Rise's Avatar
90 F-150 Hi Rise
Question Tranny Question
Hey yall, new user, I was wondering if my 90 F-150 4x4 has a AOD or an E4OD tranny by the statistics.
Thanks for any replies.
Old Apr 24, 2006 | 10:01 PM
handyman43358's Avatar
handyman43358
We need more information. Welcome to FTE by the way.
We can answer your question by more than one way. The first way is for you to give us the transmission code off the door tag. E indicated you have the E4OD. U Indicated the AOD.
The other way to determine is by looking at the shift pattern on the cluster. P R N OD D 1 indicates you have the AOD. P R N OD 2 1, with the O/D button on the dash indicates you have the E4OD. If you have the same pattern with no O/D button, you have the C6.
The other way to determine is by counting the number of bolts on the transmission pan. The E4OD has 20 bolts, the AOD I believe has 17, and the C6 has 14 I believe. I do know for sure that the E4OD has 20 bolts.
Old Apr 24, 2006 | 10:21 PM
90 F-150 Hi Rise
Thanks, handyman43358, I believe I can figure it out now.
Thanks again!
