2 Guages and No Lights!
Old Aug 6, 2002 | 09:57 PM
blastmaster's Avatar
blastmaster
Ok, when I first got my '72 F100, I removed the instrument panel before painting the interior. I noticed first, though, it lit up but there were a couple bulbs out so I replaced them while the panel was out. I put everything back after and noticed that the 2 guages on the right (temp & oil press) did not work, and there were now no dash lights. I don't know if the guages ever worked, but the dash lights did. Well I finally got around to looking at it and could not figuire it out. The Left guages (ammeter & fuel level) work, and the bulbs in the panel light individually. I quadruple checked a good connection from the harness to the panel and checked the light rotory switch. Could I have connected something else back behind the dash improperly that could have caused this?
Old Aug 6, 2002 | 10:29 PM
idealtrucks's Avatar
idealtrucks
i just got finished doin the same thing to my 1970 f100. I didnt take out the whole panel thought, just the cover and left it plugged up. I also changed my lights and they all come back on. Is what probably happened is the printed circuits have been broken when you pulled out the plug
Old Aug 8, 2002 | 12:03 PM
BB's Avatar
BB
Old Aug 8, 2002 | 07:36 PM
graymule72's Avatar
graymule72
hey blast, i had the same problem w/ my '72. i pulled the gauges out a second time and noticed that some of those the little tabs on the circuit board ( where the main plug goes ) had worked thier way loose. i carefully put them back in place w/ a tiny drop of glue. it's been working fine ever since
mike
