Caliper
Old Apr 24, 2006 | 02:56 PM
redneckboy's Avatar
redneckboy
Caliper
I was changing my front brakes yesterday. On the front passenger side I had removed the bottom caliper bolt. I was putting the new pads on and the calliper fell off the top. The caliper grease pin came out. Is this ok? I would think so cause I dont see how the grease pins are really held in.
Old Apr 24, 2006 | 03:14 PM
CAT_man_963's Avatar
CAT_man_963
That sounds normal - once the caliper is pulled off and out of the way - basically, the only thing holding the slide pins in are the rubber dust boots.
