Gearing change
Old Apr 24, 2006 | 02:50 PM
hearing8's Avatar
hearing8
Gearing change
I do lots of freeway commuting in my 1986 extracab F-250 (460c.i)...Would changing the rear gear help the gas mileage? Right now it seems like the motor is screaming at 70mph...I believe it has 4:11 in it now...I only pull a small 6 X 12 on occasion....
What gearing would you suggest?
Old Apr 24, 2006 | 04:16 PM
andym's Avatar
andym
The ones from a Ranger with a 4 banger and a 5 speed.
Seriously, lower gears will give you slightly better mileage. But you won't notice much of a difference between 4.10's and 3.55's. Maybe 1mpg? Probably not even enough to justify the expense of a gear swap. Plus, if it's 4x4, you need to change front and back.
Old Apr 25, 2006 | 09:29 AM
Sycostang67's Avatar
Sycostang67
If you wanted to go with 3:55's I have the set I pulled from my 85 F-250 4x4 that might work. Dirt cheap if you are interested. You could also try running a taller/narrower tire to bring down your freeway rpm's. I went from 3:55's to 4:10's and noticed an improvement in city mileage, but the rpms are at 3000 at 70mph.
Old Apr 25, 2006 | 09:59 AM
Kemicalburns's Avatar
Kemicalburns
yea run a tall skinny tire or look into a gear spliter. gear change can be expensive
Old Apr 25, 2006 | 04:51 PM
Duncan10's Avatar
Duncan10
Hey Guys
One thing I did hear about a long time ago was using an old 3 sp standard tranny mounted backwards to use like an overdrive transmission. Not sure if this would work or not. Has anyone else ever heard of this type of Hillbilly overdrive.
Duncan
Daleksandrovich
Mar 22, 2014 09:37 AM
Quad Racer
Computer Chips & Tuners
Mar 8, 2012 11:02 AM
Cowboy34
17
May 17, 2006 01:46 PM
7sixf150
22
Oct 9, 2005 10:01 AM
eric78ford250
Jul 1, 2002 09:46 PM
