Problem with rocker shaft assembly
Old Aug 10, 2002 | 09:05 PM
Forddrof's Avatar
Forddrof
The manual states to get all of the bolts finger tight then tighten two times per in sequence, then torque. My problem is that I can get all but one or two to go all the way to the assembly via finger, and these same ones seem to bottom out although I know they are not seated properly. What could be causing this? Thanks!!!!
Old Aug 10, 2002 | 09:56 PM
FE427TP's Avatar
FE427TP
two bolts are longer than the rest and are also reduced shank these will go in the holes in the head which are countersunk and have a oil passage for the rocker arms, the hole will be approximately 1/4"
Old Aug 11, 2002 | 07:52 AM
Forddrof's Avatar
Forddrof
I didn't catch that, that explains much. Thanks!
Old Aug 11, 2002 | 04:41 PM
jowilker's Avatar
jowilker
