electric choke installation
Old Aug 13, 2002 | 02:49 PM
gadams's Avatar
gadams
Hi all, I just ordered an Edelbrock Performer carb with electric choke, and I'm wondering where I should attach the wire for 12V for the choke (where have you guys done it?)
Greg
67 F100 390
Old Aug 13, 2002 | 03:01 PM
BB's Avatar
BB
Do you have an ampmeter or an idiot light?
Barry
Old Aug 13, 2002 | 05:26 PM
gadams's Avatar
gadams
I have an ammeter.
Greg
Old Aug 13, 2002 | 05:52 PM
BB's Avatar
BB
Cool, you can get power from under the hood and not go into the cab for it. BTW, these aftermarket electric chokes need a full +12 volts to operate properly. Getting it off the stator on the alternator is not going to cut it. It only puts out around half the charging voltage.
Since you have an amp gauge, the charging circuit is a little different in that the stator terminal on the voltage regulator is not connected to the stator on the alternator but instead gets a full +12 volts from the ignition key. This is where you are going to tap off power for the choke.
Look at the wiring diagrams in my gallery, the one that says 1969-1970 F100-350 power, charging and gauges. Find the voltage regulator, it’s just below the battery. The wire that you are interested in is the one marked 904. On the regulator, it’s the second from the bottom and is green w/ a red stripe. You want to tap into that wire with another wire that will run up to your choke. You can follow the 904 wire in the harness and tap into it at any point that is convenient. That’s all there is to it.
If you don’t want to do it that way, let me know. You can tap off power from inside the cab and run it through the firewall but that’s another story.
Barry
Old Aug 13, 2002 | 06:20 PM
gadams's Avatar
gadams
thanks BBB, very helpful.
Greg
Old Aug 13, 2002 | 07:10 PM
jds1971's Avatar
jds1971
Old Mar 27, 2004 | 11:40 AM
mlf72f250's Avatar
mlf72f250
I was about to ask the exact same question, but found this link by searching "electric choke power". Thanks Barry!
--Matt
Old Mar 27, 2004 | 01:01 PM
Mil1ion's Avatar
Mil1ion
The stator terminal on the alternator was where Ford hooked it to.
Old Mar 27, 2004 | 01:33 PM
BB's Avatar
BB
That won't work right, the Ford electric "assist" chokes are designed to run off the stator's voltage which is around 1/2 of the charging voltage. He's trying to wire up a 'electric only' choke which are designed to run off of a full 12 volts.
Old Mar 27, 2004 | 01:40 PM
mlf72f250's Avatar
mlf72f250
Looks like my '72 has the green w/red stripe wire, second from the bottom, on the regulator. That's where I'll go for full voltage. Thanks again Barry! I hope to start the beast today sometime.
Old Mar 27, 2004 | 01:48 PM
BB's Avatar
BB
You're welcome Matt!
That wire is also an excellent place to tap off 12 volt power for an aftermarket ignition module, it's hot only in the 'start' and 'run' positions.
Barry
Old Mar 27, 2004 | 05:16 PM
Torque1st's Avatar
Torque1st
Posting Legend
Nice work Barry!
Old Jun 14, 2004 | 03:57 PM
mlf72f250's Avatar
mlf72f250
Barry
I'm just about to install my Pertronix system.
I'll just use the same wire.
Thanks again, Barry!
--Matt
Old Jul 2, 2004 | 10:31 AM
Redone's Avatar
Redone
Barry, master of all Ford electrical connections, do I need to run my factory Ford electric choke for my '85 302 to the stator connection on the alternator or is there somewhere else I can connect it to?
cervantes
Oct 20, 2009 04:53 PM
MTZBoeger
Electrical Systems/Wiring
Jan 28, 2004 03:46 PM
Ron
Nov 10, 1999 01:04 AM
