Transmission options for the 400/351M
Old Mar 26, 2014 | 01:51 PM
85e150's Avatar
85e150
Welcome to FTE.
You have several options.
The first is a non-od T18, T19 or NP435. You will have to find a bell for your 400, along with all the brake/clutch pedal and clutch master etc. I'm pretty sure this would have been a factory offering, so finding a similar year donor with a stick would be the ticket.
Second is a ZF 5 speed with OD. This will require a bit more fiddling, as there are issues with input length. Details here:
https://www.ford-trucks.com/forums/1...zf-tranny.html
There are other options, some mentioned earlier in this old thread.
Old Oct 13, 2016 | 02:19 PM
Casch's Avatar
Casch
I have a 1978 f150 and I am planning on putting a twin turbo on it. I have looked into this and I know what to do as far as making the engine able to handle the power but I want to know what manual transmission would work best for the power on the 351m.
Old Oct 13, 2016 | 11:18 PM
85e150's Avatar
85e150
Welcome to FTE.
Feel free to start a new thread with a question such as that.
My answer would be the C6 automatic. I know you said manual, but an auto is a better choice.
That said, any of the transmissions mentioned above will work. There are performance transmissions that will work as well, such as the old Ford Toploader 4 speed, or late model TKO or T56 transmissions. None of those are cheap.
Twin turbo on a 351M? Are you working with a built motor already? Or a stocker?
Is this your first turbo build?
Hot Rod mag has an article on cheap turbo kits this month.
Old Aug 21, 2019 | 10:39 AM
thisoldhippy's Avatar
thisoldhippy
So What model would I need to fine the clutch assembly (pedals,slave cylinder etc ) for? Thank you for your time.
Old Aug 23, 2019 | 06:29 PM
baddad457's Avatar
baddad457
In what ? You do realize this thread is over 10 years old ?
Zorm71
31
Jan 28, 2018 06:37 PM
mustang81
13
Jan 27, 2018 08:31 AM
Tgfain
New Member Introductions
Dec 19, 2017 12:31 AM
frozenmoustache
13
Feb 1, 2017 08:01 AM
luker135
May 31, 2016 06:48 PM
