Transmission cooler
Old Apr 23, 2006 | 08:33 PM
booboo357's Avatar
booboo357
Transmission cooler
Can anyone recommend a transmission cooler. I have a 01 F150 s cab. with the 4.6l and auto trans.
I only plan on towing a 16 ft boat. I see lots of coolers online but wanted to know which brands are good and what size you would recommend. I see alot of hayden ones. are those anygood?
Sorry if this was covered before but I tried using the search feature and it wouldnt let me, said servers were under too much load.
thanks for any suggestions
Old Apr 24, 2006 | 10:36 AM
jim henderson's Avatar
jim henderson
The regular name brands are pretty safe bets. Hayden and Rapid Cool have been used by me in the past with good results. I think Permacool has a cooler. I have their remote filter and it has worked fine.
The more modern designs use stacked plates which gives you more cooling for size than the older tube style coolers.
I was told by several shop owners and from reading that you should choose a cooler that is about the size of your combined weight. For example. if your truck weighs 5000# and the trialer weighs 3,000#, I would get a cooler that is rated for about 10,000#. Don't go for the biggest cooler you can find. A tranny needs to be a t a certain temperature to operate properly so the biggest cooler may keep you from ever reaching operating temp. Of course under cooling is worse than over cooling.
Good Luck,
Jim Henderson
Old Apr 27, 2006 | 01:05 AM
booboo357's Avatar
booboo357
Thanks for the reply Jim, I think a 10000 to 12000 lbs one should work for me.
cwelchy
Feb 28, 2013 10:34 PM
Remford
Apr 29, 2012 01:00 PM
csangster
Nov 16, 2010 10:41 AM
elemint
Sep 2, 2005 10:26 PM
conan8
All Things Towing
Jan 19, 2005 07:37 PM
