98 E150 neutral switch
It won't come outta park when you push the brake if key in run position it will come out of park if you just take the key out of the lock position. It will start in park and will start in neutral and drive fine. Was told it could be the neutral safety switch.
Ok brake light switch not gettin juice and fuses good. Right turn signal also blinks dimmly and changed bulb. Did put juice to switch just to see if it would work and did come out of park that way. So ? is what to look for now??
Most Ford vehicles run right out of the fuse box to the brake switch. So if you do not have power at the brake switch, you need to trace that line back, and possibly check for power on the fuse terminals after you take the fuse out.
The later model pickup trucks also had another fuse box out under the hood. I do not know if the vans do or not.
kevin-11
Apr 8, 2025 07:00 PM
atechbuy
26
Sep 22, 2023 01:34 PM
lildebo
Aug 13, 2008 08:30 PM
