Sponsored by: Auxito
2000 power mirrors
Old Apr 23, 2006 | 09:50 AM
tsc7690's Avatar
tsc7690
2000 power mirrors
Wondering if anyone had any advice on how to change power mirrors on a 2000 f-150 extended cab? Dont feel like snapping anyhting plastic today, Thanks
Old Apr 23, 2006 | 10:42 AM
92merc's Avatar
92merc
You changing out the whole pod, or just the glass? If you have electric and you're sticking with electric, it's easy.
Pop off the panel with the window switches and remove the connectors. I think there's two screws at the bottom of the door panel and one where the switches were. Panel lifts up and off. There's only three nuts holding the mirror on. Roll your window down so you can catch the mirror when the last nut comes off. Otherwise you'll drop it or bang it against the door. The wire for the power mirror goes all the way to above the window switches. Connector up there.
Old Apr 23, 2006 | 04:59 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome tsc to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Apr 24, 2006 | 12:16 AM
deltasoft's Avatar
deltasoft
tsc, you can remove the panel by removing door handle cover-it pops out. Then there's a screw there and then ontop of panel there is plastic cover on top left side of door that is pretty long, pops out too and there is another screw ontop of panel, then last just slide up panel by holding arm rest and your good to go...just unscrew the mirror and boom.
goodluck pal!
Old Apr 25, 2006 | 08:58 AM
tsc7690's Avatar
tsc7690
thanks to all, with the advice, It was very easy but could not have been done without your help. Thank You-Scott
Old Apr 25, 2006 | 09:37 AM
deltasoft's Avatar
deltasoft
anytime bud....we're here to help always at FTE!
mck2000
2011 - 2019 Explorer
Jan 31, 2014 10:52 PM
mck2000
Ford Truck Parts for Sale
Oct 26, 2013 10:09 PM
mck2000
Sep 1, 2013 10:46 AM
whitetank
Aug 17, 2012 06:52 PM
