lowering a I-beam
Old Apr 22, 2006 | 08:39 PM
BIG66PROJECT's Avatar
BIG66PROJECT
Smile lowering a I-beam
if I put the axle on top of the springs how do I go about bringing the front down,I have seen lowering I-beams but they are spendy any suggestions would be great thanks guys you have helped me alot with my project,I want it low,loud,and tire burnin fast!!!!
Old Apr 22, 2006 | 09:27 PM
twin66's Avatar
twin66
Well, i talked to one guy about lowering the front of my 66, and what he was gonna do was put shorter springs in, and shorter shocks so they wouldn't bottom out. When I told him i was looking for dropped I-beams he said he had never even heard of em!
Old Apr 22, 2006 | 09:39 PM
BIG66PROJECT
drop
I did find one kit on ebay from canada and it acually had lowered I beams but it was very expensive,Is putting the axle on top of the spings going to drop it to much,what about driveline angles?
Old Apr 22, 2006 | 10:21 PM
Beechkid's Avatar
Beechkid
BelTech engineering has em and they are not that expensive...been around for many years.
Old Apr 23, 2006 | 12:20 AM
FirstTry's Avatar
FirstTry
the company i canada gets there kit from springtech (california i think) as far as i know expensive it is a 3/4 drop and its done right and if something fails you have someone to go down with you lol
Old Apr 23, 2006 | 12:52 AM
TremecGT's Avatar
TremecGT
We just pulled a set of after market drop axles off of my dads 65 F-100, drop me a line if interested.
Old Apr 23, 2006 | 10:41 AM
lgtwood's Avatar
lgtwood
Talking
Try DJM suspesion, the last time I checked it was about $550 for i-beams and flipped shackles, I don't know what just the i-beams will cost. This kit was for 4inch front 6inch rear drop, that is if I remember right. It's been over a year since I looked at this stuff.
Kris
Old Apr 24, 2006 | 09:31 AM
Mike G's Avatar
Mike G
The proper method for dropping the front is with the new i-beams. If you put shorter springs and shocks, nothing else is adjustable in the front end, think about what that does to your tires....
--Mike
Old Apr 24, 2006 | 09:41 AM
BIG66PROJECT
the DJM kit looks pretty good.If i swap the axle on top of the springs I'm going to have to put a c-notch in the frame right?
Old Apr 24, 2006 | 11:04 AM
twin66's Avatar
twin66
--Mike
Yes, that is why I inquired about the dropped I beams, because I didn't want just shorter springs, I didn't think that would be too good for the truck. It just seems to be more of a "cheap fix".
Old Apr 24, 2006 | 11:09 AM
BIG66PROJECT
I-beams
yes I'm going to invest in new I beams but will the shackles with the kit bring the rear down far enough?
Old Apr 24, 2006 | 12:07 PM
garbz2's Avatar
garbz2
As previously stated the typical drop is 4 in front and five in back
As i read it you want to drop the front and flip or shackle the back?
Dropped beams are the only way to effectivly lower the front TWIN I Beams. It will reasonably keep the caster and camber within somewhat of a factory spec. Dont ever anticipate (Opinions differ here) using the truck as a truck again. AIM and Dream beams are fabricated units and NOT forged Steel Billet. So wheelies and weight may be a limitation.
Adding shackels to raise the rear of the leaf spring is limited by the bottom of the bed. typically a raised leaf eye will interfere with the bed. Additionally pinion angle will need to be revised as the raising of the rear eye puts the center line of the pinion at a lower position. I true U Joint eater. this will require a C notch as the center of the axle will be raised 1/2 the distance of the added shackle legenth.
An axle over leaf flip will also require a new set of axle pads.(less than 20 bucks from Mopar or summit). this mod requires a notch of the frame, but will maintain the same pinion angle as stock. it adds about 5 inches of drop.
Garbz
I am currently correcting a bad drop job on the 64 shop truck i am doing complete with cracked frame rails from ethnicaly engineered torch lowering.
A a
Old Apr 25, 2006 | 10:07 AM
lgtwood's Avatar
lgtwood
Talking
The DJM kit I seen had reversed spring hangers for the rear end. When you use those you don't have the clearance problems, right? This is half statement, half question because I'm not sure. This is the same kit I plan on using on my truck. So it would be nice to know if I am thinking wrong(not an unusual thing, too many voices).
Kris
Old Apr 26, 2006 | 12:47 PM
clarkw123's Avatar
clarkw123
bought my drop beams from djm,dropped the front end 3'',they are very nice,think they are 550-600 dollars now,they are in all the truckin magazines
Old Apr 26, 2006 | 05:39 PM
BIG66PROJECT
Smile DJM suspension
I just got off the phone with DJM and for $862.70 you get the lowering I-beams rear shackle kit and four toxic shocks thats pretty resonable for a 4" 5" drop kit with shocks!
