Brake lights come on
Old 04-22-2006, 06:29 PM
Tango's Avatar
Tango
Tango is offline
2004 Merc Mountaineer brake lights come on several minutes after engine is off. Have tried stepping on brake and several minutes alter lights still come on.
Nothing in the forums offers solution...need some help. Thanks.
Old 04-23-2006, 02:34 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
Sounds like you need to adjust or replace the brakelight switch.
Old 04-28-2006, 12:06 PM
Exploder02's Avatar
Exploder02
Exploder02 is offline
Well, if it's anything like my 2002, the issue is not in the brake light switch.. at least on mine, the switch is NOT adjustable.. but the plug is real easy to reach.. while it's doing the brake light thing, unplug the connector, I'll bet the lights stay on.. if they don't, well, it's the switch.. cheap and easy to replace yourself. In my case, it was the Brake-Shift interlock unit in the steering column, pulling the brake light circuit to ground, and eventually destroying itself. When it happened on mine, FORD offered NO replacement for just the bad Brake-Shift interlock part, one had to replace the WHOLE steering column (really, I checked with 3 dealers and in Alldata)... I think that they've finally released a procedure and part to fix just the damaged part, much cheaper and easier.. I imagine they had a bunch of 'em go bad. Incidentally, before I finally figured out what was happening, it smoked one of my Brake Light switches (I did try that first), and finally went into a dead short, which popped the Brake light fuse intermittently, then immediately (as soon as I popped the fuse in). BTW, it's pretty exciting when you're going 75MPH down the highway w/ the cruise on, and it comes time to hit the brake (which normally disengages the cruise).. when that fuse blows (and you will be unaware of it when it happens), the cruise does not disengage immediately, it takes heavy pressure on the brake pedal to trigger the pressure switch in the Master Cylinder, which will then disengage the cruise. (yeah, the same switch, well, not exactly the same as the troublesome ones, that were setting F150s on fire).
Old 01-07-2007, 05:04 PM
nascar_20's Avatar
nascar_20
nascar_20 is offline
Hi -
I have an early manufacturer 2002 Explorer and just had a similar problem. The brake lights stayed on so when I got home I disconnected the battery and then read this thread. I disconnected the brake light switch, reconnected the battery and the brake lights were off. I then disconnected the battery, reconnected the brake light switch and battery and the lights were still off. Could this be the early stage of either problem described above? Are there some other tests I can do to try and head off problems down the road.
Thanks in advance for any advice.
- Tom
dwstenersen
01-28-2017 01:07 PM
JJock
11-29-2013 11:54 PM
michigan66
1983 - 2012 Ranger & B-Series
07-18-2011 10:17 AM
FordBear
11-11-2003 04:08 PM
martt
Aerostar
06-09-2003 09:58 AM
Quick Reply: Brake lights come on
