injector pump problem?
Old Apr 22, 2006 | 04:43 PM
mholiday01's Avatar
mholiday01
Unhappy injector pump problem?
Hey guys, I just finished going through ALL 385 or so posts on injector pump problems, but I still need to ask a question-- Problem: Crank but no start, power at both terminals at injector pump... fuel going into injector pump...NO fuel coming out of injector lines!! removed pump with some effort (ha-ha) now when I spin the pump around by hand, there is a clicking sound and there is no noticeable sucking from supply side (back middle port) what gives? Please help with any comments or suggestions
Old Apr 22, 2006 | 07:08 PM
Dave Sponaugle's Avatar
Dave Sponaugle
mholiday01,
Welcome to FTE and the IDI diesel forum.
My first guess would be the FSS (fuel shutoff solenoid) has failed.
Attach a ground to the pump housing and apply battery voltage to the front terminal on the drivers side of the IP.
You should hear a faint click as it opens and closes with the application and removal of power to the terminal.
Old Apr 22, 2006 | 07:17 PM
mholiday01's Avatar
mholiday01
hey Dave, I just did what you said to the pump, and you are correct, when 12V is applied to the front terminal, a click is heard. What does that mean? Does that have anything to do with the clicking when I spin the cam end? thanks, Mike
