Info needed for manifold
Old Apr 22, 2006 | 02:25 PM
48' fordster's Avatar
48' fordster
Hey all I need some help. i am looking to buy a carb for my engine and i found out from help on this site that it is a 1971 Torino 302ci. I have been stumped agin by my engine. the manifold has 4 holes in it. ( thinking it needs a 4 bbl) but i can only find a 2 bbl for the 302 0f my year. please help? is it a newer manifol or what? ps can i get a 2 barrel manifold for this engine? ( too much gass with a four)
thanks for your two cents(or more)
Alec
ps. i found this number on the manifold but don;t knwo what it is....
# C5AE-9425-M
Old Apr 22, 2006 | 04:06 PM
pickup_289's Avatar
pickup_289
C5AE means it came from 1965.
Old Apr 22, 2006 | 04:16 PM
85e150's Avatar
85e150
You can get a 2bbl manifold or you can buy a small 4bbl for your existing manifold. A 390 CFM 4bbl will run your motor, and flows about as much as a medium size Ford 2bbl.
2bbl manifolds should be a dime a dozen for your 302. You will need the PCV plate and good gaskets. You might find the whole set up on a car in a junk yard. Ford 2bbls are easy to rebuild, too.
Old Apr 22, 2006 | 04:39 PM
48' fordster
thanks you guys. lots of help.
Old Apr 22, 2006 | 05:54 PM
packrat56's Avatar
packrat56
48 fordster, my 302 is from a 1971 Torino as well. A stock 2bbl manifold, as 85e1 said, should be very inexpensive at a junk yard. Or go for the small 4bbl with your existing manifold. Are you going to buy a new carb or used?
Old Apr 22, 2006 | 07:43 PM
ALBUQ F-1's Avatar
ALBUQ F-1
In many cases a small 4-bbl will give better gas mileage than an equivalent 2-bbl. My son had a 72 Maverick 302 with the factory 2-bbl and it was far from economical even after rebuiilding. We put on a small Holley on an Edelbrock aluminum manifold and mileage was close to the same but it was more responsive.
Old Apr 22, 2006 | 08:39 PM
48' fordster
I just bought a 2-bbl carb from "carb exchange" they were vary helpful on the phone told us waht we needed and helped us get it. then we went on and bought a Edelbrock manifold with correct opening for the 2-bbl. thanks for all your help. well post pics later
Old Apr 22, 2006 | 09:08 PM
havi's Avatar
havi
I'll have the Roast Duck
302's were never made in 1965. 289's were available in 1965. might wanna check into what engine you really have.
Old Apr 23, 2006 | 09:25 AM
48' fordster
well i was looking at the heads and they are from a 289 and so is the manifold but the block is a 302 so i think the guy taht i bout it from was mixing a nd matching the 289 parts with the 302 block.
