Cam timing advance
Old Apr 22, 2006 | 01:30 PM
averagef250's Avatar
averagef250
Cam timing advance
Have my 390 tore down for freshening and resealing after putting 80K some miles on it in the last 2 years. It looks great. New gaskets will have it back in business. I always run cloyes chains and I've always installed them straight up, no advance. I heard recently that advancing the cam will gain a good bit of low end. The engine is a mild 390 with a 901 cam and D2 heads. Can't say I could complain at all about the torque this motor makes, but if advancing the cam would make it better I'm up to try it. The engine cruises at 1900 rpm at 70 and gets pretty good gas mileage that I don't want to mess up by advancing the cam either. Any thoughts?
Old Apr 22, 2006 | 02:24 PM
rusty70f100's Avatar
rusty70f100
Check the timing chain for wear, and put it back together. I dont know what static compression ratio you're running, but advancing the cam will increase the dynamic compression ratio, making the motor more likely to ping. It will usually give you a bit more low end and mileage though, but that will come at the cost of upper end HP. Crane ground that cam the way they did for a reason. If you want it to be different, you should probably consider a different cam. The next smaller one in the Crane lineup is the Crane 343971.
