1978 - 1996 Big Bronco
87' 302 not starting
Old Apr 22, 2006 | 01:21 PM
Erik940's Avatar
Erik940
Drove my bronco for an hour turned it off for about fifteen minutes and it wouldn't restart. It has spark and has fuel pressure at the test port on the fuel rail. Pulled off one of the intake hoses and sprayed raw gas int the intake and the engine ran but stopped when we stopped spraying gas. Sounds like no fuel is coming out of the injectors. The next morning it started right up. I let it run for a while to charge the battery. At the end of the day I tried to start it and again it wouldn't start. Bronco has done a lot of sitting. It is a spare vehicle.
Thanks for any help
Erik
Old Apr 22, 2006 | 02:28 PM
greystreak92's Avatar
greystreak92
Welcome to FTE and the Big Bronco Forum. We will do what we can to help where ever we can.
Pull the codes, replace the fuel filter and let us know what you find. If its been sitting for a while you may have draw crud into the filter from the tank.
