CEL Every 260 Miles
Old Apr 22, 2006 | 11:30 AM
njf207's Avatar
njf207
CEL Every 260 Miles
98, Explorer 4.0 Code comes up every 260 Miles as a miss shift and its on the dot every 260 miles what could cause this to happen. Help
Old Apr 22, 2006 | 04:28 PM
aquanaut20's Avatar
aquanaut20
Change your route, the truck is getting barn shy..
aquanaut20's Avatar
aquanaut20
Just kidding, are there any codes??
Old Apr 22, 2006 | 06:08 PM
njf207's Avatar
njf207
I cant remember the code but it means miss shift I know that much. If I unhook the battery it gos away untill it hits 260 miles.Any ideas
Old Apr 22, 2006 | 06:22 PM
aquanaut20's Avatar
aquanaut20
only code that I can think of is the 1-4 shift solonoid, and I dont know why that would be distance related. Need more DATA!
Old Apr 23, 2006 | 08:32 PM
AlfredB1979's Avatar
AlfredB1979
That's probably your warning to get the problem fixed.
I'm just guessing, never having owned a vehicle with a slushbox full time, but letting solenoids go to hell can't be good nor cheap to fix in the end...
Unhooking the battery is not helpful, either, since the computer has to relearn its shifting patterns, which is also not gentle on the tranny. Even the easy way (pulling the ECM fuse) does the same thing.
Ooops.
Anyway, the Haynes has several shift solenoid codes, among other tranny codes, but you didn't give us enough to narrow things down with.
Old Apr 24, 2006 | 08:12 AM
njf207's Avatar
njf207
I will have to code pulled again when it comes back on.
Tsoko24
1978 - 1996 Big Bronco
Mar 6, 2010 11:58 PM
Chazlom
2004 - 2008 F150
Jun 7, 2008 09:02 PM
Jigsaw
Nov 11, 2003 08:58 PM
jowilker
Aug 2, 2002 05:30 PM
