E350 won't keep running
I think it's fuel, and I'm tracking down the shop manuals, but I wondered if anybody has seen something like this.
It quits quicker if I pop the gas -- which adds to the thought that it's fuel.
I'm thinking that it's low pressure or a block between the fuel pump and the carb. ANy thoughts will be appreciated
ford2go
First try replacing the fuel filter, you can also put a wrag at the line where it goes into the carb and crack it while running, be careful because it should really squirt.
If it isn't the fuel filter, fuel line, the carb, carb filter. Check the fuel pump..could have a weak diaphram. Have it pressure tested.
My husband's 83 E150 302 was acting the same way for a few months last year with cutting out, hard starting and finally kept dying at stoplights. He thought it was everything else Except the fuel pump (AutoZone) as he put one in the previous year. Called the mechanic (we knew him for years) for help and finally a tow to his shop. Checked what was needed to. It was the fuel pump. My husband replaced it and it runs fine now.
I was having a similar problem with my own 81 E100 300 with cutting out of late and become hard starting. It did "die" while in town just recently, a couple of times, even hesitated while moving (was able to give the accelerator a quick couple of pumps) Finally had the van checked out by the same local mechanic after it finally "died" and would not start. This just a few yards from his shop (and after I stopped there to ask his advice) And so knew what was going on. He kept for a day to check it out thoroughly and everything checked out ok. Did not charge me a thing. But suggested my getting a new fuel pump as he thought the diaphram might be too weak to work properly under high heat conditions (it was over 104 that day) and long driving. No telling how long that pump has been there before I got the van in late 2004. So I bought a new one and will be putting it in tomorrow.
Good, honest mechanics are worth their weight in gold.
No, make that more valuable.
This is an RV, and it appears to have an electric fuel pump ( with a 4bbl). I've seen references to a fuse that could prevent the pump from running when the key was just 'on'. (would run in start). This would fit my observations pretty well. However, I can't find any sign of such a fuse, nor any good information on how things might be wired. I believe that I found the inertial switch, but that's about it. The electric pump is just very briefly mentioned in the factory manuals ( found some at the library). It apparently was only used in RVs and other cutaway applications.
Anyone have any info on this setup? I've poked around a little, but these things are CROWDED.
Thanks,
ford2go
ford2go
Good Luck and have a good day.
Thanks
ford2go
So. I ran new wires from what ( I thought) was the temp sensor. The location and
shape matched some references I checked. But it was instead -- the OIL PRESSURE SWITCH.
I would have probably tried undoing the mod soon, but the info from subford and one reference in the actual shop manual made it seem a lot more likely.
Anyway, it's fixed, and thanks to everyone. Now if I can just figure out where the
real temp sensor is -- and also ( I discovered this along the way) where I can find a fuel filter that looks like a small oil filter. ( of course it's unmarked)
Thanks again
ford2go
