Switching to automatic.
Thanks
Greg
slapping it in a standard pickup.so I am oblivious to everthing else...If the c-6 comes from an fe it makes the job alot simpler
becuase its a bolt on, bolt off job if ya know what I mean.
Fe power
1. Auto trans from any FE engine, w/ flexplate and spacers, torque converter, rubber mount, carb linkage and and shift linkage. Plus a vacuum hookup for the modulator.
2. Driveshaft and slip yoke.
3. Radiator with cooling tank, or an automatic trans cooler, and cooling lines.
4. Automatic trans steering column. Because I have yet to find an auto trans steering column WITHOUT power steering, you'll need to do that swap as well. If you can find one, great. I means you can do the projects separately. (My lack of observation doesn't mean there aren't any, by the way.)
The column switch will involve electical work, so be prepared for hours of testing if you get wires crossed!
Power steering conversion:
1. FE PS brackets. Since you want to put in AC, make sure the ones you get are from an engine which has AC, because the PS brackets are slightly different. Now, you can get the brackets from a car or a truck FE, and you will see a wide variety of different setups, even though they are all FE engines. As long as you get everything from one engine, you'll be fine, just don't mix and match. I got mine from a 76 F-100.
2. Pump, hoses (only get the pressure hose new), and PS sector. Put a new rag joint on while you're at it. Make sure you keep the pitman arm for the PS truck sector; it is different from the manual steering.
3 You may end up changing the drag link and tie rods; others here can be more specific on that.
Good luck on your project, I hope to do mine this winter!
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
I just got the engine out a few hours ago, only had to fight it a little
But it finally gave up and came on out.
