1966 - 1977 Early Broncos
Front brake question
Old Apr 21, 2006 | 04:32 PM
Fine250's Avatar
Fine250
I have a '68 Ford Bronco and have never done a 4 wheel drive with drum brakes. Are the hub casing and drum one piece, because we can't seem to get the drums off?
Old Apr 21, 2006 | 06:57 PM
ken75ranger's Avatar
ken75ranger
Kind of. Most guys take the whole assembly off then knock the studs out through the back. Just make sure you put one of lug nuts back on a few turns before you hit the stud. Once you knock the studs out you can do it like a normal brake job. It's because the old setup's are lug-centric, not hub-centric like the modern ones.
